Autor [EN] [PL] [PT] [IT] [DE] [FR] [NL] [TR] [SR] [AR] [RU] [GR] [JP] [CN] Tema: REGLA FABER(?) PARA LA INDUSTRIA CERVECERA  (Leído 8405 veces)
« en: Enero 15, 2018, 18:31:59 pm »
Hola a tod@s
Tuve la suerte de comprar hace poco dos reglas 'cerveceras' o sea para la industria de la cerveza  () ()
La primera es probablemente la Faber Castell  51/80   (versión sin número) aunque pudiera ser una Nestler...
David Rance (de la Oughtred Society) que también tiene una no ha sabido decirme si la mia es una Faber, os copio su mensaje:
Hello Gonzalo,
 Thank you for your email and I remember you from Bonn. I also regularly use your marvellous PHOTOCALCUL website for reference.
First an important distinction needs to be made. F-C issued my wooden version of the beer brewing slide rule in two different series’: (i) as part of the 5x/xx series as model 51/80 and (ii) as part of the specially commissioned series without a model number. Attached are the relevant pages out of Peter Holland’s F-C book (7th edition). My version is the one without a model number. Some 20 years later F-C reissued the same design as the 25cm 57/80 and as the 12½cm pocket 67/80. But both of these later plastic models also have a top bevelled edge with cm scale. To add to the confusion Nestler and possibly Aristo also made almost identical beer brewing slide rules. All beer brewing models are rare – possibly because of the limited market. They were only of interest to beer breweries. But this makes identification even more difficult. I am attaching some other images I collected when researching my beer brewing slide rule. The first is from Dieter von Jezierski and shows two specially commissioned beer brewing versions he found in the F-C archives. The second is of a 51/80 as identified by Hans Peter Schaub.
For such a rare slide rule there is little information in German and even less in English! “System Windisch” refers to the inventor/designer of the scales: Prof. Wilhelm Windisch (1860-1944). In 1885 he became at teacher at the VLB or Versuchs- und Lehranstalt fuer Brauerei (Research and Teaching Institute for Brewing) in Berlin, The institute still exists - see: https://www.vlb-berlin.org/en/the-vlb/history. In the 1930s the VLB was one of two main German beer brewing schools. It is believed Windisch came up with his design around 1910. I have no instructions but alcohol expert Tom Martin of the UKSRC tried to explain to me some of the basics. I have attached a copy of Tom’s email from 2008.
I hope this helps.
Peter Holland a escrito un artículo muy interesante sobre las reglas cerveceras, desgraciadamente está escrito en alemán y no existe traducción a otras lenguas mas faciles...El artículo fué el tema de una de las presentaciones del IM2013 en Bonn.
http://www.rechenschieber.org/BierBerlin.pdf
En el artículo se ve mi regla aunque la escala es ligeramente diferente.
Mi regla:
https://photocalcul.com/Calcul/Regles/Faber_Castell/faber_51_80/photo_faber51_80.html
corregido después de convertirse en una Nestler    https://photocalcul.com/Calcul/Regles/Nestler/nestler_Windisch/photo_nestlerWindisch.html
La segunda regla la vereis en este mensaje:
https://arc.reglasdecalculo.org/index.php/topic,3448.msg31051.html#msg31051
« Última modificación: Noviembre 10, 2020, 00:26:21 am por gma »
Re:REGLA FABER(?) PARA LA INDUSTRIA CERVECERA
« Respuesta #1 en: Febrero 15, 2019, 18:02:20 pm »
 Me he descqargado el pdf para leerlo detenidamente. De momento, el Título es un juego de palabras:
 "Industrie-Arbeiter brau(ch)en Bier"
Puede leerse sin la "ch" del paréntesis: "Los trabajadores industriales fabrican cerveza.", o con la "ch": "Los trabajadores industriales necesitan cerveza".
 Brau(ch)enoicos saludos.
« Respuesta #2 en: Febrero 16, 2019, 16:22:06 pm »
Uy, uy... Gma tiene una regla Faber que no tiene el JeFaZo...  shock shock
 :A :A  prev prev Saludos,  ()
« Respuesta #3 en: Febrero 16, 2019, 23:49:14 pm »
 El modelo que muestra gma según explica Peter en su articulo es una Nestler, comparación de modelos (o las de Peter o la de gma tiene la reglilla invertida):
 La de Gonzalo:
 Uno de los mas visibles detalles diferenciadores es la especie de corchete/flecha indicando la izquierda al lado de la palabras Sudhaus Gärkeller que no aparece en la Faber:
    Nestler
        Gma
       Faber
 Reversos, el que dice Peter como 51/80:
 Y el que aparece en la pagina de gma:
 Ni idea por mi parte de tipografía, pero por pequeños detalles no parece ser la misma... ???   ¿Alguien en la sala?  :a
  nv6 CSI_Regleros Saludos  nv6
« Última modificación: Noviembre 10, 2020, 00:29:21 am por gma »
« Respuesta #4 en: Febrero 17, 2019, 00:04:26 am »
Decía (15 Enero 2018)
Creo que el jefazo ha demostrado que se trata de una Nestler
Tendré que cambiarla de familia..
« Respuesta #5 en: Febrero 18, 2019, 21:37:30 pm »
En este hilo: https://arc.reglasdecalculo.org/index.php?topic=2514.msg24185#msg24185 comentábamos la diferencia en los treses de Nestler y de Faber-Castell. Los treses de Nestler tienen el trazo superior curvo, así: 3, mientras que los treses de Faber-Castell tienen el trazo superior recto.
Parece que estas reglas cerveceras no son excepción y de aquí se podría haber deducido su fabricante. Según esto efectivamente la de Gonzalo sería una Nestler.
Jefe, ¿puede usted confirmar esto del tres faberiano?
Treses faberianicus saludos.
« Última modificación: Febrero 18, 2019, 21:44:37 pm por roger »
« Respuesta #6 en: Febrero 19, 2019, 11:11:28 am »
 He echado un vistazo rápido a la colección, hasta los 30' los 3 aparecían curvados y a partir de esa década comienzan a aparecer modelos con el 3 recto, aunque no es una norma estricta ya que por ejemplo la icónica 2/83N lleva el 3 curvo.
    < 1920             1931
       1933               1934
   FC 2/83N  1974
 ForensicoRegleros Saludos
« Respuesta #7 en: Febrero 19, 2019, 12:02:54 pm »
Aún mas extraño , misma regla FC 8/20 con números "3" diferentes
« Respuesta #8 en: Febrero 19, 2019, 14:21:50 pm »
Vaya, pensé que podría utilizarse como indicio, pero parece que no es definitorio.
Lástima.
Aún así podríamos mirar a ver si hay alguna Nestler con el tres recto, para el descarte.
« Respuesta #9 en: Febrero 19, 2019, 15:14:37 pm »
En el caso de la 8/22 de GMA, hay también diferencias notables en 5, 6, 7 y 9.
Adicionalmente al cuadrado de resalte del 1.
Lo que evidencia un cambio en la fuente (font) utilizada. GMA, tienes las fechas de ambas reglas ?
« Respuesta #10 en: Febrero 19, 2019, 16:28:00 pm »
No se bien el año en que pudo ser. Pero cuando empezaron a aparecer los plotters (a nivel industrial fue ya hace mucho) hubo un movimiento de normalización de la caligrafía técnica, tratando de unificar y simplificar los símbolos caligráficos y llevarlos a escasas formas geométricas simples, o sea siempre que era posible rectas, y pocas... y si no combinadas con pocos arcos de círcunferencia simples.
Esto generaba una caligrafía técnica bastante fea, pero permitía tener las fuentes vectoriales de hoy en día con el escasísimo poder de proceso y de velocidad de trazado de aquel entonces...
¿ Tendría esto algo que ver con estos cambios ?
Dubitativos saludos
« Respuesta #11 en: Febrero 19, 2019, 16:47:40 pm »
...... GMA, tienes las fechas de ambas reglas ?
Desgraciadament de la mia no, la otra regla es del Jefazo.
« Respuesta #12 en: Febrero 19, 2019, 16:50:09 pm »
Lástima.
Ninguna regla Nestler de las mias lleva un "3" recto. En los catálogos tampoco se ven.
« Respuesta #13 en: Febrero 19, 2019, 17:18:25 pm »
Yo tampoco he visto ninguna Nestler con el tres recto.
De este modo quizás podríamos concluir que si el tres es recto NO se trataría de una Nestler. Algo hemos ganado.
Lamentablemente lo contrario nos genera alguna duda razonable.
« Respuesta #14 en: Febrero 20, 2019, 07:13:08 am »
Cita de: V2k
Posiblemente, posiblemente. Esto me recuerda ahora la historia del font Courier, bastante tortuosa.
No sé con seguridad en qué año fue, pero a nivel sobre todo europeo, y en casi todo lo relacionado con dibujo técnico, aparecieron las fuentes de la serie ISO, muy utilizadas aun hoy en día aunque, como bien dice V2k, la potencia de cálculo de cualquier aparato hoy en día es muchas veces superior a los de hace apenas 10 años.
AQUI un ejemplo de una fuente ISO Europea relativamente moderna.
Europeos saludos.
« Respuesta #15 en: Febrero 20, 2019, 08:51:01 am »
No se bien el año en que pudo ser. ...
La mayor parte de las reglas 'antiguas' francesas llevan el "3" recto!  ::)  (Lenoir, Tavernier-Gravet, Barbotheu, Marc....)
Habría que investigar a partir de cuando pasaron al "3" redondo.  nv6
Ninguna regla Aristo de 'photocalcul' con el "3" redondo recto .. gracias Jefazo por ver el error  :A
"3"_saludos
« Última modificación: Febrero 20, 2019, 19:01:46 pm por gma »
« Respuesta #16 en: Febrero 20, 2019, 09:51:59 am »
Ninguna regla Aristo de 'photocalcul' con el "3" redondo.
 Será al contrario: Ninguna regla Aristo de 'photocalcul' con el "3" recto.
 Correctos Saludos
« Respuesta #17 en: Febrero 20, 2019, 12:33:19 pm »
Por ejemplo las Diwa de mi colección tienen los dos tipos de treses. Luego pongo unas fotos.
« Respuesta #18 en: Febrero 20, 2019, 19:02:45 pm »
 Correctos Saludos
OK   ¡corregido!
« Respuesta #19 en: Febrero 20, 2019, 19:24:16 pm »
Fotos de los treses de DIWA:
DIWA Nº 201 TECHNICAL
DIWA 511-1 ELECTRO
Y también pasa con las GRAPHOPLEX:
GRAPHOPLEX 690a NEPERLOG
GRAPHOPLEX 694a TECNILOG
No hay manera de unificar.
Unificatorios saludos imposibles
