Autor [EN] [PL] [PT] [IT] [DE] [FR] [NL] [TR] [SR] [AR] [RU] [GR] [JP] [CN] Tema: Problemas con las imágenes.  (Leído 6215 veces)
« en: Julio 23, 2013, 11:13:24 am »
Hola Jefe.
Cuando trato de cargar imágenes mediante "Opciones Adicionales" me sale este mensaje.
Connection Problems
Sorry, SMF was unable to connect to the database. This may be caused by the server being busy. Please try again later.
Warning: Cannot modify header information - headers already sent by (output started at /home/reglasde/public_html/arc/Sources/Errors.php:415) in /home/reglasde/public_html/arc/Sources/Errors.php on line 346
Warning: Cannot modify header information - headers already sent by (output started at /home/reglasde/public_html/arc/Sources/Errors.php:415) in /home/reglasde/public_html/arc/Sources/Errors.php on line 347
Warning: Cannot modify header information - headers already sent by (output started at /home/reglasde/public_html/arc/Sources/Errors.php:415) in /home/reglasde/public_html/arc/Sources/Errors.php on line 348
Warning: Cannot modify header information - headers already sent by (output started at /home/reglasde/public_html/arc/Sources/Errors.php:415) in /home/reglasde/public_html/arc/Sources/Errors.php on line 351
Warning: Cannot modify header information - headers already sent by (output started at /home/reglasde/public_html/arc/Sources/Errors.php:415) in /home/reglasde/public_html/arc/Sources/Errors.php on line 352
Warning: Cannot modify header information - headers already sent by (output started at /home/reglasde/public_html/arc/Sources/Errors.php:415) in /home/reglasde/public_html/arc/Sources/Errors.php on line 353
Connection Problems
Con el Postimage me carga un cuadradito con una cruz.
No sé si estoy haciendo algo mal, pero antes conseguía cargarlas sin problemas.
De las imágenes que trataba de cargar, ninguna pesaba más de 200 Kb.
Re:Problemas con las imágenes.
« Respuesta #1 en: Julio 23, 2013, 15:01:48 pm »
 A ver..., pruebas...:
« Respuesta #2 en: Julio 23, 2013, 15:03:49 pm »
 Mas pruebas:
« Respuesta #3 en: Julio 23, 2013, 15:08:59 pm »
 Con PostImage:
Con ImageShack:
 Me sale un error:  You must provide a valid auth token or dev key. see http://code.google.com/p/imageshackapi/     ??? ??? ???
 Y nuevamente con el propio servidor de ARC:
« Respuesta #4 en: Julio 23, 2013, 15:13:21 pm »
 En resumen, quitando lo de ImageShack (que tengo que averiguarlo...) parece que los demás funcionan, quizás pillaste una punta de carga... ???
  Probatorios Saludos  (y como bien dice uno que rebien conocéis, estas maquinas las carga el diablo  >:D  :u0udiablo:...  ;D ;D)
« Respuesta #5 en: Julio 23, 2013, 15:24:30 pm »
Muchas gracias jefe, sabiendo que el problema es mío veré si es que estoy haciendo alguna cosa mal.
