Autor [EN] [PL] [PT] [IT] [DE] [FR] [NL] [TR] [SR] [AR] [RU] [GR] [JP] [CN] Tema: Nuevos modelos FC 1/87 400g, 61/87, 66/39 y 20/70  (Leído 8591 veces)
« en: Septiembre 02, 2011, 11:16:25 am »
Si no recuerdo mal, creo que este foro esta dedicado a las reglas de calculo, por lo que me pongo en faena:
 4 Nuevos modelos FC en colección!!:
 1/87 400g:   http://fabercastell.reglasdecalculo.com/1_87_400g/1_87_400g.htm
 La que faltaba de las archiconocidas 1/87, esta con las escalas trigonométricas en versión centesimal, datada en Noviembre de 1964
 61/87:  http://fabercastell.reglasdecalculo.com/61_87/61_87.htm
 Una de las primeras versiones series 6x/xx (y "hermana" menor de la 1/87), de la que acabaría siendo las mas popular de las FC de bolsillo: la 67/87, datada en Septiembre de 1940
 66/39:  http://fabercastell.reglasdecalculo.com/66_39/66_39.htm
 Otra de las raras series 66/xx, datada Junio de 1936.
 20/70:  http://fabercastell.reglasdecalculo.com/20_70/20_70.htm
 Diseñada por el mismísimo Dieter Von Jezierski  (ver http://arc.reglasdecalculo.org/index.php/topic,1654.0.html), y segun me explicaba en un email:
 The 20/70 is a simple , but rare item. Yes I designed it personally.
It was the end of the slide rule era. The Copyright was 1976,
pocket calculators were dominant.
I tried to give a chance to our slide rule manufacturing with a model, which did calculate all problems, which were difficult or not so commode with the calculator. At first the  five important slide rule scales again, then proportions as
> rebate deduction and additional,
> then the at that time very much used, but new  "added value taxes"  (Mehrwertsteuer),
> the gasoline consumption (Benzin-Skala),
> "sliding time " not fixed hours of work, noting by a time clock (Gleitzeit-Skala)
> and a table for weight   female -Height-male
This "slide rule " was a flop , could not reach great sales.
The best business was with advertising imprint.
  Y ya van 275!!, si la  >:D endemoniada  >:D cámara de fotos me deja pronto empezare a subir imágenes de modelos "OEM" de Faber Castell: Dietzgen, Boots Ring Plan, etc..., y eso sin contar con el viejo proyecto de las Klawun y las Wichman...  :P
 Afaenados Saludos
Re:Nuevos modelos FC 1/87 400g, 61/87, 66/39 y 20/70
« Respuesta #1 en: Septiembre 02, 2011, 13:44:06 pm »
¿Te ha sido difícil conseguir la 1/87 400g?
He estado media vida, localizandola, para aplicarlas al "cálculo mecánico de líneas eléctricas aéreas de media tensión", para mí ha sido como buscar una Faber Castell 2/84N, alias Mathema.
¿Es posible una réplica?
 rofl
Desmathemadoicosos saludos
« Respuesta #2 en: Septiembre 02, 2011, 14:23:03 pm »
"hermana" menor de la 1/87"
Preciosa regla, que maravilla de 61/87, observando el reverso, aprecio bién el año de fabricación ¿septiembre de 1940? no hablemos del estado de conservación, parece salida de fábrica.
También, es de suponer que en los albores del siglo XXI, estará catalogada como otra mas, de las "IMPOSIBLES"
Envidiacosicos saludos
 nv11
Continúas, manteniendo una "MATRICULA DE HONOR" en fotografía.
« Respuesta #3 en: Septiembre 02, 2011, 14:29:37 pm »
Trata de traducir de la FC-20/70, las palabras en alemán.....
Gracias por adelantado.
 thank
Adelantadoicos saludos
« Respuesta #4 en: Septiembre 02, 2011, 17:26:36 pm »
Aaaaaahhhhh...... El foro era sobre reglas...... Con razón ! nv13
Es que no hay muchas novedades regleriles por aqui...
Entre que la billetera está flaca, y los precios se enloquecieron: Aristo 0903LL=50?, Aristo 89=45?, FC317=60? por nombrar algunas ...  La cuesta va muy empinada... (A esos precios, no las venden... pero no las bajan !)
Hermosos ejemplares Jefazo. Felicitaciones !!
¿ Qué le pasó a la 66/39 ? ¿Es pintada la superficie, o se amarilleó?
Superficiales saludos.
« Respuesta #5 en: Septiembre 02, 2011, 17:38:13 pm »
"Aristo 0903LL=50€, Aristo 89=45€, FC317=60€ por nombrar algunas ...  La cuesta va muy empinada..."
Efectivamente, aunque ya sabes que no me gusta comprar via "internet" dar mis datos me hace temblar, gracias que mis "dos espías sliderulesicos" si observan algo o yo veo algo, los aprovecho para adquirir alguna.
No obstante, la situación económica no me acompaña, para todo lo que yo quisiera, veo a mi país sin "brújula" y tal vez lo mismo le pasa al resto de Europa, ya veremos como finaliza este 2011.
 ???  ::)  shock
Brújulaicos saludos
« Última modificación: Septiembre 02, 2011, 17:48:11 pm por AHMS »
« Respuesta #6 en: Septiembre 02, 2011, 17:53:38 pm »
Efectivamente, aunque ya sabes que no me gusta comprar via "internet" dar mis datos me hace temblar .....
Antonio:
En mi caso, fuera de la Argentina, no compro por el eterno problema aduanero.
Pero localmente, si bien el 90% lo compré por internet, las compras a particulares las hago sólo a los que puedo ir personalmente a pagar y a retirar. No quiero pagar y luego ver que me entregan otra cosa o la cosa en mal estado...
Con el pago por internet... en los sitios seguros y conocidos, no tengo problemas... Yo hace añares que no piso un banco o una oficina de pago de faturas... Toco madera, pero en 1000-1500 operaciones nunca tuve un conflicto !
OnLíneos saludos.
« Respuesta #7 en: Septiembre 02, 2011, 19:25:16 pm »
Jorge, es que con estos calores ... ¡se está tan bien en la barra del bar con unas cervezas  () y filosofeando  nv14 sobre el mundo....!
la 1/87 400g  ... si la tienes en doble   ya sabes....  :a
venga .....  tambien 'photocalcul' estrena reglas, como esta Aristo de las primeras, de los años 50  luego desapareció del catálogo, al menos con esa referencia Nr 966
 podeis echarle un vistazo al manual (en inglés)
http://www.photocalcul.com/Calcul/Regles/Aristo/photo_aristo966.html
Aristotelicos saludos
« Respuesta #8 en: Septiembre 03, 2011, 06:17:29 am »
GMA, la Aristo 966 está muy bien,para mi tiene la combinación mínima imprescindible de escalas, y cursor ajustable.
Y además, la claridad de las graduaciones es impecable, como en casi todas las Aristo. Hecho en falta el ajuste de los estatores, pero si está bien ajustada de fábrica, no tendrá problemas.
Una muy buena regla.
Aristotélicos saludos.
« Respuesta #9 en: Septiembre 03, 2011, 11:17:59 am »
 Me he pasado épocas buscándola y dejándome la vista en las imágenes de cada anuncio de 1/87 a ver si por casualidad se despistaba alguna 400g y mira por donde en Junio aparece una bien clarita en el anunciado (y baratita) ;D, y evidentemente preguntando al vendedor si no tenia manías en enviar a España.  El estuche no aparece en las fotos ya que era de una 1/54 "normalita" y corriente... :(:
 La verdad, si que debe ser rara, ya que me imagino que se servían bajo pedido.
venga .....  tambien 'photocalcul' estrena reglas, como esta Aristo de las primeras, de los años 50  luego desapareció del catálogo, al menos con esa referencia Nr 966      podeis echarle un vistazo al manual (en inglés)
  Anda!!, mira por donde el nene "tene" una, pero con H!!...  ???:
http://coleccion.reglasdecalculo.com/aristo/966h.htm
 Es exactamente igual, Dennert & Pape incluido, solo cambia el cursor.
 Aparece 523 en el lado opuesto de la inscripción D&P, por lo que siguiendo las instrucciones de datación: http://coleccion.reglasdecalculo.com/aristo/datacion.html debe ser el lote nº 3 de 1952
 ¿El manual es scan tuyo? lo digo para fusilarlo mas adelante...  >:D, aunque este modelo no tiene mucho misterio en cuanto a escalas.
  Datados Saludos
« Última modificación: Septiembre 03, 2011, 14:17:44 pm por jfz62 »
« Respuesta #10 en: Septiembre 03, 2011, 15:07:52 pm »
Ya lo dice el refran, "la suerte no es para quién la busca, sino para el que la encuentra"
Eres un "SEA AND WITH AZO" *.*
 nv12
Te exijo, que estes al loro y me localices otra por 9 ?, los portes los pago yo, ¡no faltaba mas!
 nv10
SEAANDWITHAZOICOS saludos
 *.* (Alvaro+Jorge II)  :a  :a  :a  :a  :a  les prohibo que realicen la traducción y la hagan pública, ya saben el dicho................
 "el que quiere peces, que se moje el "cobre+logroño"
« Respuesta #11 en: Septiembre 03, 2011, 19:06:58 pm »
mi Aristo 966  lleva la marca 503 o sea contruida en 1950 lote3
si rebuscas en el Aristo book encontrarás el manual .. ( pum!  fusilado!)  nv7
las dos reglas son identicas salvo el cursor
en el AristoBook aparecen varios catalogos de 1950, 1955, en los dos aparece la regla como 966H...sin embargo en una lista de precios de 1950 aparece como 966 pero con una dimensión de 30 cm , en vez de 33 cm  :o :o :o (seguramente un error)
el manual ,con un sello de 1952, la llama 966
¿que es el H?
¡que follones se traían!
follónicos saludos
« Última modificación: Septiembre 04, 2011, 19:08:40 pm por gma »
